saltbranch
New User
Would like some opinions please. My new 1955 TO-35 gas powered, the lift will lift shredder with enough RPM. Once I push the clutch to put in gear, 3pt drops to ground fast. I have cleaned all the milky old fluid, flush with diesel and got the case cleaned up nice. I put the NAPA GL1 in. The lift works a little faster, but same results, drops when clutch is pushed in. I changed the O-rings, all 3 off them on the stand by tube in hopes I would be lucky. Still same results, looking in from the dip stick cover, i see turbulence coming from what I think is the pump.
It sounds like a pump or rebuild is in order. I am waiting for my video to get here so I can watch that and I have a service manual. While I am in there what else would be suggested to look at for repair/upgrades. I have the single stage clutch from what I can tell.
It sure is a neat little tractor and I look forward to bringing it back into action
