TractorLinks.com
Show Parts for Model:
Re: need some advice
s19438
03-15-2014 06:14:33
as far as the engine goes not a whole lot. I turned it over by hand, took off the valve cover and everything seemed ok. not very dirty.
now we need to attach fuel line and wiring and we should be good to go ?????
Steve@Advance
03-15-2014 08:49:15
 Re: need some advice in reply to s19438, 03-15-2014 06:14:33
The only thing that comes to mind that would damage the engine would be if it were to not have oil pressure when it started. Since you have the valve cover off, I would start it up with the cover off, watch to see that all the rockers drip oil, then check the valve lash.
And since the gas tank is off... Have you looked inside for rust? Good assumption it will be rusty if it's original and been stored outside.
Providing the engine is good, the transmission will need to be drained and flushed. Notorious for collecting water. It gets in around the shifter boots and the upper three point mount boot.
