TO-30 tractor was running pretty good but started to notice unusual racing or missing for a few hours, then dead.
Normally I use an after market battery cut off switch just in case, but I left it connected. Next day battery is dead. After charging the battery I hear clicking from the center of the tractor every time I open or close the battery cut off switch.
The starter motor engages as it should when the shifter is in position.
If I'm lucky the racing and missing was due to lack of spark caused by low voltage. Unfortunatelly, I can't remove the spark plugs and look for a spark even after 24 hours of soaking in PB blaster.
