TractorLinks.com
Show Parts for Model:
Re: Crank Timing Gear
Jason S.
03-13-2014 10:40:29
The TO-30 had both an inner and outer thrust washer and shims to control the endplay. It looks like somebody didn't have shims or was too cheap to buy any and used a homemade one. I would just get the proper thrust washers and shims and see how if you can get the end play set right.
Jason S.
03-13-2014 10:46:47
 Re: Crank Timing Gear in reply to Jason S., 03-13-2014 10:40:29
Even if that homemade shim did work it looks like its in the wrong order. The order from the block should be inner thrust washer, shims,outer thrust washer,thrust plate, then the gear
