TractorLinks.com
Show Parts for Model:
Re: Carb problems
Z-man
02-28-2014 10:07:22
it probably won't make a difference by leaps and bounds but adjusting the idle screw should make the engine run smoother at some point, the more gas you gas the engine the less the idle screw does. make sure the idle speed is around 400 rpm and the timing is set at 6 degrees btdc. the slow the engine is turning the more effect the idle screw will have when adjusted
