Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Carb problems
ditchwitch
02-28-2014 09:49:43
ok Z-man, no leaks but i did do a little adjusting on the throttle linkage, actually the tractor runs great but still the idle screw does not have any effect at all.
Z-man
02-28-2014 10:08:43
 Re: Carb problems in reply to ditchwitch, 02-28-2014 09:49:43
what tractor are you working on?
Z-man
02-28-2014 10:07:22
it probably won't make a difference by leaps and bounds but adjusting the idle screw should make the engine run smoother at some point, the more gas you gas the engine the less the idle screw does. make sure the idle speed is around 400 rpm and the timing is set at 6 degrees btdc. the slow the engine is turning the more effect the idle screw will have when adjusted
Copyright © 1997-2015 Yesterday's Tractor Co.
