Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Wengers 35 Picture
Jason S.
02-27-2014 16:29:50
I looked at the pics and I think it is the flash of the camera causing it to look different plus the fact that paint will look different when it is sprayed on a piece of sheet metal verses a piece of rough cast steel. The paint can not lay down on rough cast because of the texture. I think you want the definitive answer on the correct shade of green but there probably isn't one. You could probably line up 10 of those tractors that were original and the shades of green would vary from each other. The shades would vary depending on which manufacturer supplied the paint,who mixed the paint,who sprayed the paint,the air pressure it was sprayed at,and how dark the red oxide primer was underneath the paint. I've been into the auto body business for over 20 years now and all of the above will change the color especially when their is a metallic or pearl in the color. Remember a while back I was searching for the right shade of Ferguson gray? I used the codes from FENA and PPG's code had no blue in the paint but Sherwin Williams code for Ferguson Gray did have blue in it and that was the shade I remembered as a kid and I went with that. I do know Sherwin Williams was an original supplier of paint to Ferguson. Try their code and see if you like it better.
