Yesterday's Tractor Co. Fast, Friendly Parts Service
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
miner09
s19438
02-26-2014 11:28:19
108.36.215.249
did you buy a sparex manifold?
I know you know I bought but I was wondering....yesterday me, my son and my SIL could not get the upper two inside manifold nuts to fit. did you have the same problem? also did you use new or used nuts?
[Reply]   [No Email]
Del Huebner
02-28-2014 06:01:16
173.28.58.0
 Re: miner09 in reply to s19438, 02-26-2014 11:28:19
I replaced a manifold last summer on a TO-30, but I do not know the origin of the new manifold, it came with the tractor when I bought it. If I remember correctly I used a thin open end wrench and 3/8 socket set. I had to purchase a small breaker bar for the 3/8 set as the ratchet would not fit the socket in the close quarters. I replaced all the nuts with new ones. It was a little uncomfortable at times but did get it done and it did not leak.
[Reply]  [No Email]
vp
02-27-2014 18:58:22
71.54.73.161
replaced the manifold on my to 30 bought it from stieners made in U S A did not have to do anything bolted right up
[Reply]  [No Email]
Griz
02-27-2014 10:31:54
74.5.136.50
Bought one from here. It had a lot of grit in the runners. I put a lot of paint on a wad of clothe and pulled it through the intake runners to seal the grit. Didn"t want all of the grit going into the cylinders.
[Reply]  [No Email]
Inno
02-27-2014 07:29:19
206.172.0.204
I bought one from here ( I think ) . Not sure if it was a sparex one but I was not too impressed with the fit. I had to do a LOT of die grinding to make enough clearance to get a socket in to tighten. Unfortunately I don't think there is any other option aside from used parts.
[Reply]  [No Email]
Jason S.
02-27-2014 05:52:19
192.43.65.245
I would say they are all sourced from the same supplier reguardless of who you buy them from. I used one and had to grind on it. Yor other alternatives is to use allen head bolts, use a smaller nut that has been drilled and retapped to the correct size, or use one of the original manifolds.
[Reply]  [No Email]
s19438
02-27-2014 06:24:53
108.36.215.249
 Re: miner09 in reply to Jason S., 02-27-2014 05:52:19
I bought one about eight years ago from a local ford tractor dealer who is also a sparex vendor. I don't remember if it was a sparex unit or what but I do know I had no problem with the nuts fitting other than a tight fit.
[Reply]  [No Email]
Dan S (NY)
02-27-2014 04:40:27
24.176.140.94
I have installed a couple of new manifolds over the years and had to do a little die grinding to get clearance for the nuts to go on in several places. They weren't from Sparex but they may have the same problem.
Dan
[Reply]  [No Email]
miner09
02-26-2014 16:19:50
70.196.2.150
Haven't installed it yet. Been to cold to paint. I install after painting. Will let you know. I know they are always hard to get on.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
