to-35 manifold brass nuts
s19438
where can I get them ? I know I have seen them online somewhere but now I can't find any.
thanks
steve
(quoted from post at 17:05:53 02/24/14) where can I get them ? I know I have seen them online somewhere but now I can't find any.
thanks
steve
Steve, I ordered some from Bolt Depot.
And, like John said, McMaster-Carr will have them, too, but I found Bolt Depot's website to be a little more user-friendly.
ok. so my ferguson parts manual does give nut size. what do I need ?
forgive my ignorance and once again thanks !
s.
(quoted from post at 18:20:25 02/24/14) ok. so my ferguson parts manual does give nut size. what do I need ?
s.
Steve, I don't have a TO-35, but the TO-20/30 Parts Book calls for 3/8" NC Nuts, and 3/8 Small (SAE) Flat Washers.
I think the 20/30 and 35 can all use the same manifold, so the nuts should be the same. (You may want to confirm that before you order.)
Use Milk Of Magnesia, dries to a fine powder. This powder will not deteriorate with heat. Normal anti seize will deteriorate and disappear with time during extreme heat cycles. M.O.M. will leave an even coat that works like nothing else.
Have used this for years and have never had a problem removing nuts or bolts after 30-40 years of manifold heat, or any where as far as that goes,,
Tim
Most any auto parts store, at least those that have been around a while will have brass manifold nuts in several sizes and threads.
Yeah, I think my brass ones came from an ACE hardware not far away, they were in the flat drawers, not the bins, call and ask them! Manager should know...
