Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
6v or 12v
gene zick
02-23-2014 13:31:00
216.126.134.174
If the tractor has an alternator, is it a 12volt system? I installed headlights on it and they burned out immediately
[Reply]   [No Email]
Steve@Advance
02-23-2014 21:57:02
107.203.134.67
 Re: 6v or 12v in reply to gene zick, 02-23-2014 13:31:00
Look at the battery, if it has 3 cells, (caps where you check the electrolyte level) it's 6v, if it has 6, it's a 12v.
The lamps will be marked with their intended voltage.
If you find the lamp voltage to be correct, and they burned out, better check the alternator output with a volt meter. There could be a problem with the alternator or wiring causing it to overcharge. With a 12v system, the voltage should level off at about 13.5 to 14.5 volts at fast idle.
[Reply]  [No Email]
ShadetreeRet
02-23-2014 21:49:51
76.3.100.234
If the battery has six filler holes, it is twelve volt. Since you didn't specify what brand and year tractor it is, leaves a lot of possibilities. If it was originally a six volt that has been converted, the bulbs or lights should have been changed also, unless the previous owner never used the lights. Although it is a bit unusual for both bulbs to pop at one time, if the tractor was originally twelve volt,then you have a problem elsewhere. Just some thoughts.
[Reply]  [No Email]
phil(va)
02-23-2014 18:00:46
71.2.164.166
You didn"t say what voltage the headlight bulbs were. Other respondents are assuming they were 6 volt. Presumably you know what they are since you installed them. Yes, alternators are generally 12 volts. But it occurs to me you could have 12 volt bulbs and they may have burnt out for some other reason??
[Reply]  [No Email]
2tractors
02-23-2014 15:44:14
192.222.24.245
Most times an alternator is an indication of a 12 volt system so if your bulbs burn out I'd expect to see 6V somewhere on the bulb.
[Reply]  [No Email]
Richard L
02-23-2014 14:08:19
24.247.233.247
My impression is alternators are 12 volt unless you request a 6 volt. Sounds like yours is a 12 volt alternator, working on a 6 volt tractor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
