Tom Bowman
Anybody ever had a cracked rocker shaft support?
I have.
I noticed it when I was installing the rocker assembly, after torquing the head bolts on the TO-20.
I suspect a previous owner tightened the bolt on the rocker shaft support a bit too much.
I've got a lead on a used rocker shaft support from a good source, at what sounds like a good price.
I hadn't planned on messing with the rocker shaft - until now.
I read the Shop Manual for the instructions on disassembling the rocker assembly - it doesn't sound too bad, as long as you keep track of where everything goes.
Any other advice?
I have.
Any other advice?
