TractorLinks.com
Show Parts for Model:
Re: fergie TO-20 3 point/hydraulics issue
smittyslilfergie
02-03-2014 04:43:25
I did use the 90w tractor oil from Tractor supply , this is the oil for everything ...should I replace with a lighter fluid ?
Jason S.
02-04-2014 18:30:03
 Re: fergie TO-20 3 point/hydraulics issue in reply to smittyslilfergie, 02-03-2014 04:43:25
The GL1 90 weight mineral oil will work fine. Yes it is thick when it is cold but if you let your tractor warm up first it will be fine. I have GL1 in mine and I routinely use it in cold weather. I just let it warm up for a bit before I use it. Go ahead and use it since you already have it in there. No reason to waste $50.00 worth of oil.
Steve@Advance
02-04-2014 18:06:57
Yes 90W is going to be too heavy, especially in cold weather. The hydraulics will move very slowly. But it will work until you get the problems worked out, just in case you have to drain it to work on it.
I would also be concerned with the cleanliness of the bottom of the case. To my knowledge there is no filter on the pump intake. Since there was water in it, there's probably rust falling down from where the water condenses above the oil level. All you can do is clean it best you can, vacuum and blot it out before refilling it.
