Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Pto won't engage
01-31-2014 06:15:09
If it was grinding as you tried to engage PTO, then it maybe adjustment of the PTO clutch or you have too much play in the pedal. There should be 3/8" of free play measured under the footrest to the top of the Clutch Lever arm. If it is the Lever on the side that is loose like you seem to say, remove the Round Plate with the Lever and you may have just sheared the pin through the lever, this is easily replaced. You will lose some oil when you remove the Plate. If you are having trouble with the clutch adjustment, email me and I will send you the information that you need to re-set it.. If it is grinding and you keep using it then you will damage the gears that drive the PTO John(UK)
