Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Remove crank pulley TO35 Stan Diesel?
01-30-2014 07:50:52
I would, thank you. The I & T is lacking in some of the detail I would like. Does that manual have any information about the valve timing events? I'm going to put my degree wheel on the crank to check the valve timing events injector pump timing from the hole in the block & flywheel. I can back figure after I insert the 1/4 dowel through the block into the flywheel. I'll document the information once I have it. From some other literature I have read you can alter the cam timing in 1-1/2 degree stages depending on how you remount the chain wheel to the cam sprocket.
