TractorLinks.com
Show Parts for Model:
Re: Tea 30 rear lift arm
samn40
01-27-2014 00:07:19
If you have adequate lifting gear or if you are quite strong you will be able to remove the complete axle trumpet from the transmission housing. It is more awkward than real heavy.You may have a worn housing where the pin fits as it must have been dripping oil for some time? Or did it snap? You will need to put some sort of sealer around the new pin and really tighten it up before fitting the cotter pin. Also ensure your new paper gasket is the same thickness as the old one or you may have to adjust the shims for end float....... Sam
Twozerofour
01-27-2014 09:51:36
 Re: Tea 30 rear lift arm in reply to samn40, 01-27-2014 00:07:19
Thanks Sam, It has been dripping for a while but we have been gettign a foot of snow a week so i have been working it pretty hard.
The pin dose not appear to be broken it just looks like the cotter pin broke and the nut backed off.
I am running a modified 8.25x24.5 logging truck wheels with 1200r24.5 tires 55gal of calcium in each with Modified Logging Tryggs. I have broken a few welds so far. It gets quite a bit of traction. I also run 300lbs on my blade for more cutting power.
I will try to R&R the horn tonight, i should be able to leave the hole brake assembly intact for this process? Other than unhooking the linkage?
