Tom Bowman
I know the photo isn't the greatest, but it looks like there's a little gap between the gasket and the oil pan.
The oil filter didn't fit as far over the center tube as I thought it would, and the screen was down below the oil pan a little on one side. (The cover and screen seemed to suck up pretty well when I tightened the center bolt - I tried not to overdo it.)
I'm a little concerned, because when I dropped the oil pan for the first time, I discovered that a Previous Owner had installed the filter cover and screen upside down, and had used the wrong filter. (The spring and felt washers were also missing.)
I thought maybe the P.O. was trying to deal with problems with the fit of the screen, filter and cover.
Do I just need to add a little oil, and see if it leaks?
