Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Weeping oil - is it ok to drive? fergie TVO
Ray Baxter
01-10-2014 13:47:08
One of my concerns is that I may have contributed to the problem by accidently adding too much kerosene and running the tractor. Could this possibly cause the problem?
Steve@Advance
01-10-2014 14:52:11
 Re: Weeping oil - is it ok to drive? fergie TVO in reply to Ray Baxter, 01-10-2014 13:47:08
I assume you washed out the transmission with kerosene? Yes, that could have contributed to it, especially if what your seeing is transmission oil instead of engine oil. It may be black because it's carrying out clutch dust as it runs down.
I think I'd go ahead and run it awhile and see what happens. Mine ran for years with the front trans seal leaking, finally got time to fix it, didn't seem to hurt anything.
I assume your oil levels are good, not overfull. Might want to watch both and see if you develop a pattern of consumption, then keep the level just below full, see if that helps with the leak until you can get in there and fix them... Them as in do both while it's apart.
miner09
01-10-2014 14:51:23
Just keep a check on engine oil and make sure the cotter key(hole) in bottom of housing is kept open. If it doesn't get worse I would say it is OK for now to keep running. The tractor will have to be split to repair.
504
01-10-2014 18:35:12
 Re: Weeping oil - is it ok to drive? fergie TVO in reply to miner09, 01-10-2014 14:51:23
You can try the only magic in a can I will use, and that is any Lucas product that applies.
Copyright © 1997-2015 Yesterday's Tractor Co.
