Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
rear wheel weight
ed12
01-09-2014 11:56:44
24.55.207.130
Has anyone used anything other than calcium or plain water for weight in the rear wheels. I was thinking of using a mixture of antifreeze and water. Has anyone done this? I am concerned that antifreeze may damage the tube.
[Reply]   [No Email]
jfnewt
01-11-2014 20:58:53
24.125.199.54
 Re: rear wheel weight in reply to ed12, 01-09-2014 11:56:44
I used -20 anti freeze if you go to the local dollar store it will cost a lot less than antifreeze 1.50 to 2.00 $ compared to 4
[Reply]  [No Email]
Joe Scribner
01-10-2014 05:28:01
23.29.217.182
I just recently loaded the rear tires on my TE-A20 with windshield washer fluid. It's good to -40C which is also -40F. If it gets colder than that I'll be staying in ! I've also heard some folks are using Rv antifreeze. Either one will work well. It's not quite as heavy as the calcium chloride but it's close enough. I put 30 gallons in each rear tire and at 8.2lbs/gal that's 246lbs per tire. With my duo-grip chains and the washer fluid I'm getting very good traction. Now I just have to go get my new front wheel weights and I'm in business.
[Reply]  [No Email]
ed12
01-10-2014 09:01:44
24.55.207.130
 Re: rear wheel weight in reply to Joe Scribner, 01-10-2014 05:28:01
Thanks for the response guys, you have given me the direction I was searching for.
[Reply]  [No Email]
Bruce(OR)
01-09-2014 19:10:27
97.115.24.90
Beet juice not recommended by some tire makers.
[Reply]  [No Email]
Richard L
01-09-2014 16:59:27
66.227.227.90
You do not want to use just water in them as it can freeze and damage the tubes and tires or all the weight would be in one spot and I would think it could give that tractor a ride you would not like. I am sure it has been mentioned in the archives about using water and antifreeze also Beet juice also windshield fluid. If you use the windshield fluid check to see what degree it is mixed to.
[Reply]  [No Email]
Jason S.
01-09-2014 16:58:37
174.237.0.234
When I had new tires mounted on my TO-20 back in the summer they used RV antifreeze to fill my tires. The old tire in the back that blew out had antifreeze in it and the rim was perfect. That tire blew just because they were in bad shape and badly dry rotted. It had nothing to do with the antifreeze.
[Reply]  [No Email]
Richard L
01-09-2014 16:51:01
66.227.227.90
Ed, I don't think you would have to worry about the antifreeze damaging the rubber tube. It runs through the rubber radiator hoses without hurting them too much.
[Reply]  [No Email]
Boss Hog
01-09-2014 14:52:32
50.122.29.33
Tire shops have something new now that's much better than the old calcium chloride. Can't recall the name of it offhand.
[Reply]  [No Email]
IHRedRules
01-09-2014 15:10:14
50.33.246.206
 Re: rear wheel weight in reply to Boss Hog, 01-09-2014 14:52:32
I believe what you are referring to is Rim Guard, which is the beet juice. folks are also using windshield washer fluid.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
