RandyB(MI)
Some of you wanted to see my Fergy TO 20/back blade. Bought non-running for $700 and blade for $225. Already had rebuilt starter/drive and all new ignitionand new muffler.Also put in new axle seals. Flywheel ring gear was slid back out of range. Fixed that and new cork on 3pt control and throttle. Rebuilt carb and set all specs where they should be. At zero degrees it starts and runs perfect. Loaded rears so handles the 8" ARPS HD blade nicely. No it won't plow a foot of wet snow but as long as I get out there after abt 3-4" it does just fine. Just a little "working tractor" that looks presentable and am not afraid to scratch it up. Has had a factory 30 replacement block sometime in it's life. Doesn't smoke a bit and everything works like it should....accept for the NEW temp guage I shouldn't have got from TSC..gotta take that back. Anybody ever just put an elect sending unit in the water neck and run an elect guage on one of these?? Anyway here's some pics. If you are "correct police" you may want to turn the page.By the way, I bolted an old JD plow clevis (horozontal loop) to the drawbar and put a pin on the blade frame to fall into it when lowering blade to act as a stabilizer when blade is angled. Works perfect. Ties blade to drawbar when it's down so angle can't push blade sideways. Randy B.
