Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1954 TE-A20 Throttle rods
Joe Scribner
12-23-2013 13:32:49
23.29.217.185
Was using my TE-A20 to clear snow from the driveway and had one of the throttle rods come apart. I managed to pop it back on and use the tractor just fine but will need to replace it. The one that came off is the lower end from the Governor. Are these rod ends still readily available? Are they just standard rod ends I can get from an auto supply? Thanks for any suggestions. Joe
[Reply]   [No Email]
Inno
12-25-2013 15:27:20
64.229.43.113
 Re: 1954 TE-A20 Throttle rods in reply to Joe Scribner, 12-23-2013 13:32:49
I put all new ones on my TO35, ordered them from McMaster Carr, www.mcmaster.com
I can't remember the size but I could post the part number if needed.
[Reply]  [No Email]
Jason S.
12-24-2013 20:14:12
174.228.3.133
Most hardware stores carry those ends. You can can them in different sizes and right and left hand thread. I bought some for another project a while back at my local Ace Hardware.
[Reply]  [No Email]
Bob (Aust)
12-24-2013 13:56:25
124.185.184.193
Does your TEA20 have ball joints?
Here are the original throttle connections on my 1953 TEA20:
[URL=http://smg.photobucket.com/user/Woomera/media/Rechrome1.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Woomera/media/ThrottleRod.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Woomera/media/Link3.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Woomera/media/Throttlelever1.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Woomera/media/Link1.jpg.html][/URL]
You could make the replacements. Less problems than ball joints.
Bob in Oz
[Reply]  [No Email]
John(UK)
12-24-2013 07:22:47
79.76.248.221
We have had ppl get these before locally from their supplier, depends how good your local supplier is tho. From your description it reads that it is the vertical rod at the back of the Generator, but there is no joint at the bottom of this, it attaches by the spring. I take it that you must mean the throttle link under the dash panel, you can get these from a Sparex Dealer as part S-42875 (MF part 181672M91) for the complete rod... John(UK)..fergusontractors@hotmail.com
[Reply]  [No Email]
Joe Scribner
12-24-2013 18:29:24
156.34.152.55
 Re: 1954 TE-A20 Throttle rods in reply to John(UK), 12-24-2013 07:22:47
Sorry for my poor description John ! It was the vertical rod that comes up from behind the generator. It disconnected at the top not the bottom like I previously said. Guess I should lay off the egg-nog when posting !
The ball-end or rod-end as I called is rusty and worn out. Some great replies here. I really appreciate it.
[Reply]  [No Email]
Charles in Aus.
12-24-2013 01:02:15
211.30.61.158
The small piece of wire inside the socket end wears flat and lets the ball out . Find a helical spring about the right diameter and snip off one coil , use this to replace the wire you removed . Works a treat , the tension of the coil holds it in the groove and the increased diameter stops the ball end from falling out .
[Reply]  [No Email]
samn40
12-23-2013 17:00:35
31.51.75.118
Check to see if it has a slot in the end. If it has.... this type can be tightened with a regular slot screwdriver. Sam
[Reply]  [No Email]
Trac
12-23-2013 15:35:07
67.237.5.26
That"s on the ball fitting i have seen them some were but you should be able to crimp it closed a little with pliers
[Reply]  [No Email]
Richard L
12-23-2013 17:24:48
66.227.226.250
 Re: 1954 TE-A20 Throttle rods in reply to Trac, 12-23-2013 15:35:07
Agco has them for the TO 20/30. Don't know if it is the same as TE series. What Agco has are not exact copies but they work very well. If I was you and wanted exact copies I would contact someone in the UK and ask if they would like to help you.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
