Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
TEA-20 Vanguard remote Oil filter adaptor..# 2
John Deere D
12-22-2013 19:53:09
204.244.59.75
TEA-20 Vanguard Engine OIL BLOCK adaptor
Had a chance to use my brothers machine shop before he retired
[Reply]   [No Email]
Charles in Aus.
12-24-2013 00:57:32
211.30.61.158
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to Trac, 12-22-2013 19:53:09
Brilliant ! well done , a triumph of clean functional design , just like Harry would have liked .
[Reply]  [No Email]
John Deere D
12-24-2013 08:24:05
204.244.59.75
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to Charles in Aus., 12-24-2013 00:57:32
Engine on Test Stand. Filter shall be placed in a more user friendly position once Engine attached to assembled to Tractor. Presently located here for test run on stand
Bob/Canada
[Reply]  [No Email]
John(UK)
12-23-2013 08:37:22
79.76.247.25
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to John Deere D, 12-22-2013 19:53:09
It isn't really a Vanguard Engine, it is similar but it wouldn't fit into the Vanguard car. Come to that all the engines they made could be said to be Vanguard Engines as they fitted versions of the Gas and Diesel in the Vanguard Car. Unlike the Diesel which was a 20c, the Carb engine was only recognised by the description of the bore size..i.e. 80 or 85 or 87 mm.. I think that you may have got one of those filter adaptors from a Triumph sports car which used a version of this engine John(UK)
[Reply]  [No Email]
Tony in Mass.
12-23-2013 07:27:40
71.192.19.81
Since you did all this work so far, you might want to build a little removable cage around it all. A couple years ago when I posted a pic of the side of my late 60's Perkins gas 152, some one brought to my attention how... vulnerable? a modern spin on is compare to a steel canister model... yours now hangs even lower, so check it out before going in the woods...
[Reply]  [No Email]
2tractors
12-23-2013 06:11:36
192.222.24.245
Just wondering if you have ever experimented with the pressure relief adjustment, sprung my oil gauge by collapeing the spring all the way.
[Reply]  [No Email]
John(UK)
12-23-2013 08:20:26
79.76.247.25
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to 2tractors, 12-23-2013 06:11:36
Why would someone screw the Relief Valve adjuster fully home? John(UK)
[Reply]  [No Email]
2tractors
12-24-2013 04:55:02
192.222.24.245
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to John(UK), 12-23-2013 08:20:26
Someone having trouble with the oil pressure dropping from 60 lbs down to 10 and wanting to eliminate a weak spring. I did seek your advice back a year or so ago and received prompt and informative emails on the oil flow and the oil bango fitting.
[Reply]  [No Email]
John(UK)
12-24-2013 06:23:48
79.76.248.221
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to 2tractors, 12-24-2013 04:55:02
Yes I remember that....but on any adjuster you never screw it fully, just a couple of turns will enable you to see what happens when you adjust it There is always a chance that you may get the spring coil bound. All the Best wishes for Christmas and the New Year....John(UK)
[Reply]  [No Email]
2tractors
12-24-2013 07:50:32
192.222.24.245
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to John(UK), 12-24-2013 06:23:48
Not to mention what it did to the gauge, reads 40 lbs with engine off. leason learned. Merry Christmas to you and yours.
[Reply]  [No Email]
John(UK)
12-24-2013 08:08:24
79.76.248.221
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to 2tractors, 12-24-2013 07:50:32
Thank You for that.
You will never do that again....what a way to learn though...John(UK)
[Reply]  [No Email]
Bob (Aust)
12-22-2013 20:26:02
124.185.184.193
That is nice! Very well done!
I have been looking for a spin on filter adaptor for my TEA20. I know there is one available for the Triumph TR3/TR4 engine which I think should fit the Fergy.
Bob in Oz
[Reply]  [No Email]
John Deere D
12-23-2013 03:27:06
204.244.59.75
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to Bob (Aust), 12-22-2013 20:26:02
I machined a spin on oil filter adaptor for my 1951 TEA-20 Fergy. Vanguard Engine Seems to work well. I shall send more pictures later to night. Threaded portion into ORIGINAL housing is a 7/8" NF thread...Male portion is to fit your choice of filter. Top of ORIGINAL housing was threaded to fit a NPT plug. Spacer was machined from ALUMINUM
Bob/Canada
[Reply]  [No Email]
John Deere D
12-23-2013 18:17:20
204.244.59.75
 Re: TEA-20 Vanguard remote Oil filter adaptor..# 2 in reply to John Deere D, 12-23-2013 03:27:06
Here's another shot of my latest design
TEA-20
Bob/Canada
[Reply]  [No Email]
John Deere D
12-23-2013 18:13:27
204.244.59.75
I designed this filter adaptor and it works great
Bob/Canada...TEA-20
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
