1952 TEA20 85mm 12V. I recently changed the sediment bowl assembly as the shut-off valve had failed on the old one.I drained the gas from the tank and replaced the sediment bowl.
It fired right up as usual, ran it for about 20 minutes then shut it off. Tried to restart it after about 15 minutes - no luck!. It will turn over but will not start - the red ignition light does not turn on when the key is turned to start. Could it be the ignition switch itself? Any ideas?
