There is a lot of side-to-side slop and about .045" of end play on the clutch shaft. The tapered roller bearing should have a small bit of preload and that preload is adjusted by adding/removing shims at the rear bearing housing retainer.
I [i:34d701b7a6]really[/i:34d701b7a6] don't want to tear this tractor any more apart than it already is.
What are ya'll's thoughts on this for a repair? Machining a 1.0" x 7/8" x .050" thick washer and installing it between the input shaft roller bearing and the gear it normally would butt against. This would give the roller bearing .005" preload.
Did I mention that it's not an option to tear this down any further?
I'll post pics of where I'm at on this resto when I get to my other computer.
Thanks for the help,
BillL
BillL
