Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
TO 35 Broken starter motor nose cone
abrahamseven
12-13-2013 16:00:47
OK my starter was acting up and I removed it to find the nose cone broken. I pulled the inspection plate and I found two nose cone pieces . Now , Norm the rebuilder says this is very common on the Ferguson starter. He says in has something to do with the engine kicking back and can brake the nose cone. It is from, timing or using to much ether. I don't use ether and my timing should be good. It starts right up with not much drag on the starter. I have pro-tronics and it is easy to start. Also the armature was really bent.Your thoughts would be welcome .
thank you
steven
This post was edited by abrahamseven at 16:01:31 12/13/13.
abrahamseven
12-16-2013 16:05:29
 Re: TO 35 Broken starter motor nose cone in reply to abrahamseven, 12-13-2013 16:00:47
I went to Norms this morning too get my starter and check the bendix spring. The spring was ok and while I was talking to Norn I asked him what the start was 6 or 12 volt, he answered 6, so I asked hin change it to 12. I think this is my problem ad under the circumstances so does Norm. The timing is good, it starts immediately and I never have to use ether . so we will see. You can bet i am going to keep an eye on it. The starter rebuild with new Armature . 12 volt fields new drive labor $350.00 . I know I can get a new one cheaper but Norm started on it and ordered parts and I couldn't back out. Just part of the fun of owning an old Ferguson Tractor, I guess. Thanks guys for all you comments and help. I put Protronics in Fergie and replaced the Points , that is why it starts fast no kick back. I am going to get a new crank for it though.
steven
This post was edited by abrahamseven at 16:08:30 12/16/13.
Ed H.-OH
12-15-2013 15:12:58
Hello! What Norm the rebuilder said is true, When my 35 was still 6 volt, On a cold winter day I went out to start it and it was turning over so slow that it fired before top dead center and kicked over backwards and broke the nose cone. I welded it back up, and when it was real cold I jumped the starter with 12 volt, starts right up that way, now mater how cold it gets. I later converted to 12 volt, That worked good till i started using the tractor a lot and the battery got charged good then the starter started slaming in hard and broke it again. So i bought a 12 volt starter and have no problems since. Those are the 2 reasons the nose cone breaks that i know of.- Hope this helps- ed
Duner Wi
12-15-2013 17:29:00
 Re: TO 35 Broken starter motor nose cone in reply to Ed H.-OH, 12-15-2013 15:12:58
I think it is possible to have the mechanical advance hang advanced on occasion and when cranking kick back and break nose cone.
Ed H.-OH
12-16-2013 14:46:49
 Re: TO 35 Broken starter motor nose cone in reply to Duner Wi, 12-15-2013 17:29:00
Dunner, Hello, My tune up specs calls for 6 deg. advanced. And they advance to 23 deg. or so at 2000 rpm to compensate for engine speed as it takes a little time for the dist. to fire the cylinder. When it's cranking normal speed, by the time the cylinder fires it's already past tdc.I would think. When it's turning so slow you can watch the fan blades go around and it fires at 6 deg. it's likely to kick over backwards-Just my opinion. Have a good Holiday-ed
JerryCPP (WA)
12-15-2013 10:07:48
A broken nose cone is usually caused by not letting the starter stop completely before trying again. Also, if you hit the starter when the engine is rocking back from a non-start. When I worked at a Massey dealer in the "60s, we kept a few noses in stock for the diesel starters. I still remember the starter number: 1107512.
John(UK)
12-14-2013 07:59:11
There should be a spring washer between the Pinion and the Nose Cone, so that the pinion hits the spring washer and this acts as a shock absorber John (UK)
Steve@Advance
12-13-2013 17:29:07
That's a good question... I doubt that timing or either has anything to do with it, small engine, heavy flywheel isn't going to have much kick back power.
You said it was acting up before it completely broke, what were the symptoms?
Are there any missing, worn teeth on the ring gear? Is the ring gear properly seated against the stop on the flywheel? Is it possible the starter drive came apart or failed to disengage? Probably hard to tell now that it took a hit when the housing broke. You're not running a 6 volt starter on 12 volts are you?
The only other thing that comes to mind is something came loose from the clutch and wedged between the flywheel and the starter while it was running.
So long as it's working good now I think I'd just keep an ear on it and hope for the best.
Gregg/Ohio
12-13-2013 21:27:50
 Re: TO 35 Broken starter motor nose cone in reply to Steve@Advance, 12-13-2013 17:29:07
Bendix return spring on small starter gear, weak or broken. lets bendix gear SLAM into starter housing extra hard and breaks it. I learned the hard way. Gregg
abrahamseven
12-14-2013 05:36:22
 Re: TO 35 Broken starter motor nose cone in reply to Gregg/Ohio, 12-13-2013 21:27:50
Gregg ,that makes sense about the spring . That is where it breaks at the nose cone with the bushing in it. I dug out two of them when i removed the clutch inspection cover . I going to call Norm and have him install a new spring when he puts my starter back together. Thanks guys or all your comments and advise.
steven
2tractors
12-14-2013 05:34:04
That sounds right as mine is a gas and no either used on it, yet it broke.
Copyright © 1997-2015 Yesterday's Tractor Co.
