TractorLinks.com
Show Parts for Model:
Re: Tony's hybrid!
Tony in Mass.
12-08-2013 06:38:23
If I had bought the even better TO20 next to this one...for the same price... none of you would be able to pick on me woodya? I always had a flair for the imported and exotic...cars, beers, wine, women...tractors??? and usually come out broke and disappointed... me mum told me I'll never learn.... she was sooo right.... More pics Sam, of the casting numbers and lift cover this time... as I blew this up, I see what looks like cast tags in the same spot as mine near the port hole, and the cover is close at this angle...why don't you put this one in your suitcase and bring it to the next show for us??? Where'd you get the spiffy top link with all the notches? The FENA show in Warren Ohio by any chance? !!!! You got a magic idea ther Same! I'll paint the starboard side Rustoleum smoke grey, and the port side Ford grey and vermillion... magic idea! Where have I seen something like that before?? Hey maybe mine will be Miss December 2015??
Hopefully by this evening I'll have a change to dig further, this weekend trying to put it in a better spot before we get snowed in or something... I should collect exotic tropical weather.. that'll be my next hobby!!!
Jason S.
12-08-2013 07:30:37
 Re: Tony's hybrid! in reply to Tony in Mass., 12-08-2013 06:38:23
Where's the pics Tony? That top link is required for the Ferguson A-EO mowers, the drag type disc and some other implements. I have one myself. Remove the dipstick cover and look inside. Your TEA should have that aluminum bridge on the control fork like the TO-30. At least that's what the Internet is saying. Also if you can see the lift cylinder, the 9N cylinder is smooth and has no reinforcement ridges where the bolts go thru to the top cover. All the Ferguson ones I have seen are reinforced. I can take a pic of the two style of lift cylinders side by side if you want. That should help you narrow down what top cover you have. If you see no bridge and a smooth cylinder then it's an N cover more than likely. The pump won't matter. The 9N and Ferguson pumps are pretty much identical. The 9N lift cover will work also it just may not have the marks that the TEA originally did.
Tony in Mass.
12-08-2013 07:45:41
 Re: Tony's hybrid! in reply to Jason S., 12-08-2013 07:30:37
I already posted or emailed you all the views worth taking pictures of Jason, without the [HF]...what else is there to focus the camera on? When it all comes apart, on the ground, on a sunny day, we'll try again. And noooo... I got enough on my plate I don't need a gear reduction anything that looks like that...
Jason S.
12-08-2013 07:35:33
Your top cover is different than this TEA's cover isn't it? Don't you wish you had the epicyclic reduction box that this one does?
Tony in Mass.
12-08-2013 15:04:52
 Re: Tony's hybrid! in reply to Jason S., 12-08-2013 07:35:33
No pics today Jason, not enough daylight to get stuff done nevermine pointless photography... but... in the process of moving... pushing , not starting- the MF35 with the standard 23C... the same non [HF] marked parts on the TEA are also not marked on the - I presume UK made 35.. The arsend is no help in evidence to the other, it has the 2 stage clutch etc.. and it is now part of the 202.. which I wasn't in the mood to uncover today... didn't get above freezing at all today... winter's here for good...
