Generator Questions
I'm a FORD man but need to know what the generator specs are for a TO20 Ferguson. Were they supplied by LUCAS or DELCO? What is armature shaft diameter? What is bearing part number? What is armature thread size? What is the output in amperes?
Tim 'PloughNman' Daley(MI)
Tim, there's a TO-20 Owner's Manual in the "Manuals" section, over on the "other" N Board.
Like Trac says, it's a Delco-Remy, and the Manual says maximum cold output is 15-17 amps.
That's about all that's in the Owner's Manual.
I can check my Shop Manual and Parts Book at home, but it may not answer all of your questions, either.
They used a couple of different generators on the TO-20. the 1101404 was 11-13 amps and 1100509 was 17 amps. .669' 20 thread and the diameter should be 0.563in and 0.669in on the armature shaft. The bearing is a common 203 ball bearing.
