Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: confused
JMOR
12-05-2013 10:57:07
Quoting Removed, click Modern View to seeI gave you the answer......correct current level keeps them from "burning up"!
Maybe more hand holding is in order. You don't see a resistor in diagrams, so why not burning up? Well, just maybe someone used the correct coil, let us say with a 3 to 4 Ohm primary resistance, such that they obtain a safe/correct current level.
1948jr
12-05-2013 11:13:20
 Re: confused in reply to JMOR, 12-05-2013 10:57:07
now we are getting close. did they use a 12 volt coil with a built in resistor back in lets say 1964?
JMOR
12-05-2013 11:38:04
 Re: confused in reply to 1948jr, 12-05-2013 11:13:20
Quoting Removed, click Modern View to seeTo the best of my knowledge, the ONLY car that ever came from the factory with a coil with a built in resistor was 1953-1955 Chrysler Imperial (AutoLite coil). Now, what virtually all posters are calling a "coil with built-in resistor" is in fact not! What they are is a coil wound with appropriate wire length & diameter & metal properties to yield those higher primary resistance measurements, such as 3 instead of 1.5 Ohms. I haven't a clue as to when the 3 & higher Ohm primary coil windings first appeared.
Jason S.
12-05-2013 16:26:10
 Re: confused in reply to JMOR, 12-05-2013 11:38:04
I said extra windings of wire inside the distributor...
JMOR
12-05-2013 17:14:35
 Re: confused in reply to Jason S., 12-05-2013 16:26:10
Quoting Removed, click Modern View to seevery good.
