TractorLinks.com
Show Parts for Model:
Re: confused
1948jr
12-05-2013 10:39:48
you guys dont seem to be getting the POINTS you are not answering my question.
JMOR
12-05-2013 10:57:07
 Re: confused in reply to 1948jr, 12-05-2013 10:39:48
Quoting Removed, click Modern View to seeI gave you the answer......correct current level keeps them from "burning up"!
Maybe more hand holding is in order. You don't see a resistor in diagrams, so why not burning up? Well, just maybe someone used the correct coil, let us say with a 3 to 4 Ohm primary resistance, such that they obtain a safe/correct current level.
1948jr
12-05-2013 11:13:20
 Re: confused in reply to JMOR, 12-05-2013 10:57:07
now we are getting close. did they use a 12 volt coil with a built in resistor back in lets say 1964?
JMOR
12-05-2013 11:38:04
 Re: confused in reply to 1948jr, 12-05-2013 11:13:20
Quoting Removed, click Modern View to seeTo the best of my knowledge, the ONLY car that ever came from the factory with a coil with a built in resistor was 1953-1955 Chrysler Imperial (AutoLite coil). Now, what virtually all posters are calling a "coil with built-in resistor" is in fact not! What they are is a coil wound with appropriate wire length & diameter & metal properties to yield those higher primary resistance measurements, such as 3 instead of 1.5 Ohms. I haven't a clue as to when the 3 & higher Ohm primary coil windings first appeared.
Jason S.
12-05-2013 16:26:10
 Re: confused in reply to JMOR, 12-05-2013 11:38:04
I said extra windings of wire inside the distributor...
JMOR
12-05-2013 17:14:35
 Re: confused in reply to Jason S., 12-05-2013 16:26:10
Quoting Removed, click Modern View to seevery good.
Jason S.
12-05-2013 10:52:50
JMOR did answer your question. In simple terms the 12 volt coil that was installed has the resistor inside the coil. The resistor inside is extra windings of wire. You can use a 6 volt coil with the external ballast resistor or buy a 12 volt coil that has internally resistance in the windings. Either way you end up with the correct voltage to the points which is why they dont burn up.
