Hi! I"m replacing a botched 12v conversion. I have an aftermarket alternator bracket to install. Problem is, I"m not sure what this was supposed to look like in the first place, and I think there"s something extra in here that I should remove. It will be a bear to remove, so I thought I"d get an expert opinion first.
There is a 1/4" metal bar between the crankcase and the whole radiator support assembly. On the left side, that assembly bolts directly to the case. On the right, there"s this bar between the two, and the new alternator bracket won"t fit with it in there. I"m not sure if that bar was part of some sort of original generator bracket that I should have, or if I should just take it out, which will require loosening those two big bolts that hold the front of the tractor onto the case.
I"d post a pic, but I"m on my cell phone, and it doesn"t seem to work.
