TractorLinks.com
Show Parts for Model:
Re: radiator
2tractors
11-26-2013 06:03:37
She does have rosy red cheeks but looks like she needs her diaper changed.Is this babe yours? After the vinegar and head cleaning the "gauge" did read in the green but with finally getting some flow the steam and the infared told the true story.
Tony in Mass.
11-26-2013 10:02:19
 Re: radiator in reply to 2tractors, 11-26-2013 06:03:37
See now, if you learned French, you'd know is wasn't for sale... well the way I word things... maybe you still wouldn't know... Inno can barely figure out my French, and he's in real 'courier de bois' country...
I wouldn't mind having one... even if they are all diesels-!!
So what exactly you got there? Is that a French made gasoline 35? or??
I think you need a yellow pages. You need to bring that radiator to someone who will re-core it, or unsolder the top and bottom and check each tube. It can't be so exotic that a new core can't be fitted. I would need some pictures to do any further thinking and pondering the meaning of radiators.... brace rod on the left or right.... angle of the top and bottom hose necks... got to be interchangeable with something else out there...
2tractors
11-26-2013 17:20:05
 Re: radiator in reply to Tony in Mass., 11-26-2013 10:02:19
It"s made in Denmark and I tried running a skew down thru the top and was lucky to get it out again,seems most of the acummulation came loose with the vinegar and cooked hard in the radiator, the donor 35 neck needs to be turned 30 degrees and the inside of hood bent plus a dose of black pepper to stop its leak. Original standard radiator also has 2 flues soldered shut with po leaks.Closest thing we got to french down south are the canadians.
Jason S.
11-27-2013 17:15:38
 Re: radiator in reply to 2tractors, 11-26-2013 17:20:05
Have you ever cleaned one with lye or draino?
