TractorLinks.com
Show Parts for Model:
Re: Electronic Ignition
Bob (Aust)
11-12-2013 05:26:52
Adam.
From your post it appears you have 12 volt ignition? You have a 12 volt battery? You have a 6 volt coil with resistor to drop the primary voltage?
If your battery is 12 volts you have a 12 volt ignition and need a 12 volt Electronic Ignition kit. Make sure you get the correct polarity, I assume negative to ground? (Reverse polarity on electronic ignition and you will fry the unit!)
Do yourself a favour, get rid of the 6 volt coil and install a 12 volt high voltage coil to get the full benefit of the electronic ignition. If you are installing a Pertronix unit, buy their high voltage coil.
Bob in Oz
'53 TEA20
Adam Zimmerman
11-12-2013 16:24:58
 Re: Electronic Ignition in reply to Bob (Aust), 11-12-2013 05:26:52
Thanks for your input. That"s what my dad and I thought I should do but we just wanted to make sure before I went and bought an ignition.
