Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Overherating on a standard 35
Jerry/MT
11-10-2013 18:03:19
For a fuctioning down flow radiator, the very top of it should read the almost same as the coolant gauge temperture and the bottom should read much cooler.
A total internally blocked radiator will be cold throughout because no hot coolant is flowing through it. If it"s partially blocked internally, then it will be hot on top and much cooler at the bottom if the air side is working properly I think this is what you are saying.
If the air side is totally blocked, then the radiator will he hot all over.
2tractors
11-11-2013 06:40:40
 Re: Overherating on a standard 35 in reply to Jerry/MT, 11-10-2013 18:03:19
That sounds resonable but I would think even the top would be somewhat cooler than the source of the heat. The third word gauge reading the coolant stayed on zero while the infared read 180 and when it was boiling it read in the green so without having numbers the gauge is not of much use.I"ll check the manifold temps with one of the other tractors and compare.
Copyright © 1997-2015 Yesterday's Tractor Co.
