gears
Alright everybody I recently aquired this tractor and found that it once had a loader installed (radius arms bent/reinforced, hood hacked open to check radiator (missed with the first hole) and fill fuel) I noticed that the front pump shaft is still sitting in the middle of the front axle pin and it likes to puke oil from the front seal once you shut it off.
Is this common to machines that ran a front mounted hyd pump? Or is it just due to the fact that it's 60 yrs old?
Anything I should know about pulling the front pulley? I plan on yanking the front cradle off to replace the hammered pin and bushing anyhow. Do they make a repair sleeve for the pulley if it's scored heavily?
Thanks
Thanks
