Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hydraulic Fluid Overfill--What to Expect on TO-30?
Del Huebner
10-30-2013 06:28:05
You might get lucky like I did. About a year ago I brought a TO-30 home and after we loaded it on the trailer oil started running out the weep hole in the clutch housing. When I got it home I found the gear case had been way overfilled and it was milky. I thought for sure I would have to replace the seal (split the tractor). I drained all the old milky oil and replaced with new and filled it to the bottom bolt hole on the dip-stick cover. I knew the clutch had to have oil on it but it never was a problem and the weep hole only had an occasional drip which is not abnormal. Like I said I think I got lucky, Maybe you will too.
Copyright © 1997-2015 Yesterday's Tractor Co.
