Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: alternator conversion bracket TO-20
Dan S (NY)
10-27-2013 18:38:10
Like Tony said, you have a replacement block that was designed to replace a Z120 but they made them from the Z129 castings. You should also have a boss on the same side of the block back near the bell housing where the Z129 external oil filter would have been mounted. Those nubs in your picture are drilled and tapped in a Z129 block for the generator bracket so there is no reason you can't do it. I don't know how deep to go, but there is plenty of room there.
Dan
bdunegan
10-28-2013 17:34:02
 Re: alternator conversion bracket TO-20 in reply to Dan S (NY), 10-27-2013 18:38:10
dont mean to hijack this post, but you answered a question for me that i was getting ready to post on here. I too have a TO20 ser# 28804 that evidently has a replacement block. my mounting bosses arent drilled either, and i have the oil filter mounting boss. someone made an alternator mount for mine that bolts on the same place as the first pic, but raises the alternator higher to allow for axle pivot. on the other side of block where the z number is, mine has z12 raised and cast in, then a flat spot with just the number zero stamped in making z120. it also has no rivets at all above starter where serial number plate goes. this answers my questions before i ask them. is there any advantage having the 129 block over the 120 ie thicker cylinder walls maybe?
Dan S (NY)
10-28-2013 18:11:35
 Re: alternator conversion bracket TO-20 in reply to bdunegan, 10-28-2013 17:34:02
Here is a section of the original blue Ferguson shop book that discusses the replacement blocks and differences between the Z120 and Z129.
Dan
bdunegan
10-28-2013 18:44:28
 Re: alternator conversion bracket TO-20 in reply to Dan S (NY), 10-28-2013 18:11:35
so with the exception of the crank bearing inserts being different, if i need engine parts(getting ready to replace governor) do i still order them for to20(z120 block) or to30(z129 block)? i am asuming that cylinder bore and such is still same as regular z120 or does it match z129? i know that majority of parts is the same for both but have seen some that were specific to the model of engine.
Dan S (NY)
10-28-2013 19:01:45
 Re: alternator conversion bracket TO-20 in reply to bdunegan, 10-28-2013 18:44:28
The governor is the same for the Z120 and Z129 (and Z134) engines. As to the sleeves, they would have bored the replacement block to fit the Z120 sleeves as it was intended to replace a Z120. I have one of these replacement blocks in my TO20 and when I bought the sleeve kit for it I got the Z120 kit and it fit fine.
Dan
bdunegan
10-28-2013 19:18:48
 Re: alternator conversion bracket TO-20 in reply to Dan S (NY), 10-28-2013 19:01:45
thank you very much for the info. it answers a lot of questions i was about to ask. mine also has the tsx458 carb on it which was(duh) used on the to30 engine. i am going to replace governor in mine due to not working at all even after adjustment and also has a knocking in governor timing cover. not bad but i am not use to the noise. almost sounds like something rolling around in there when idling. other than that, tractor runs great with 22-25 lbs oil pressure at a warmed up idle and even runs my woods 5' brush hog better than my 51 8n does.
