could use some help
s19438
I need to remove the dash on a 35. I did this about ten years ago and I remember it was not a job I enjoyed due to the throttle linkage. any one have tips for the dash removal ?
thanks.
It would help if you could stand on your head. But seriously. Remove the battery, remove all the bolts holding it on, the oil pressure tube, steering wheel (can be challenging), any wiring that might be in the way and unbolt the throttle rod/friction disc plate from the bottom and it shouldn't be too bad. It also helps to have little fingers.
To me the hardest part is pulling the steering wheel and for that I used 3 old lawn mower blades on the back side to hold the puller hooks with bungee to wrap on the blades.
