Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: to-30 over heat
10-16-2013 05:16:25
I'll move it down, i was going off my i/t manual. can any one tell me the diff on radiators? 5 or 8 or 12 fins per/in how to tell a good from cheap? is there any good test for the water pump? i doesnt leak, and the bearings feel good.
Jason S.
10-16-2013 06:06:14
 Re: to-30 over heat in reply to 30smta, 10-16-2013 05:16:25
Fins or tubes? Fins are what is on the outside of the radiator and don"t have any effect on the cooling it"s the tubes behind the fins that matter. If you want a good radiator get one from Agco. You will pay more but you will get a better fitting and lasting radiator. If you have an original radiator you could have it recored. The cheap aftermarket radiators are just!! They don"t last long and don"t fit well. If the bearings are tight in the water pump and there isn"t any water coming out of the weep hole then it should be good, but I have seen cases where the impeller came loose on the shaft which in that case the pump would seem good but when running the impeller would hardly spin. Have you tried flushing the motor and radiator? Btw...always run with a thermostat...without one all your getting is increased fuel consumption and increased wear on the engine.
