TractorLinks.com
Show Parts for Model:
Re: Getting the PTO bearing out.
samn40
10-16-2013 00:50:23
Try screwing in the pto cover it may give you something to grip, There is only the 'O' ring holding it. You may have to use a slide hammer but for all the time you need one you could make up something?....Threaded bar, a big washer and nut to catch inside the housing and something heavy to slide against a nut on the other end. Even if you can cut a pice of flat bar to fit inside the housing, drill a hole in the middle to take the threaded bar and wriggle it into place then fit the other end through something like say the 9 hole draw bar and lever it out ? Good luck.....Sam
Jeff-oh
10-16-2013 09:42:46
 Re: Getting the PTO bearing out. in reply to samn40, 10-16-2013 00:50:23
Thanks. I Have plenty of TO20 covers. If they fit that give me something to grip.
By the time I got the rubbish bins out, and other required domestic chores done it was getting dark and starting to rain.
On the plus side. The bearing looked ok. From what I could see.
