Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hydraulic Lift Cover
John(UK)
10-15-2013 09:11:53
The Lift Cover will smash if you change the Safety valve and fit the later valve which opens at a higher pressure. OR if the bolts securing the Top Cover to the transmission housing are not torqued tight enough and it will move. It will also crack if you drive too fast over rough ground and the implement bounces on the 3 point. When it bounces It will crash down and that is when the damage is done. Later tractors had a heavier Top over and worked at a higher pressure, they also had a larger Lift Cylinder John(UK)
