Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Bottom plow and disc harrow
Jason S.
10-14-2013 16:55:51
First of all, are your tires loaded? That is going to determine a lot of how much plow you can pull and how big of a disc you can pick up. I have a 2 14" MF #62 plow that I pull with my TO-20 so your 30 will handle a 2 14" with no problems. The TO-30 was rated to be a 3 14" plow tractor. Personally I prefer my Ferguson disc plow over the moldboard plow. It pulls much easier and doesn"t leave a hard pan like moldboard plowing does. Beware when shopping for a moldboard plow most older moldboard plows like Ferguson,Dearborn,Ford,etc...you can not get wear parts for them very easily anymore and they are very expensive when you do find them. If your rear tires aren"t loaded you will find plowing can be difficult depending on your soil type. Your tractor should be able to handle a 6.5" disc but depending on how heavy it is built you will want the front tires loaded as well or you will not keep the front end on the ground when the disc is picked up and your trying to turn. A quality disc will be heavy built. If you can find one a Ferguson or the later Massey Ferguson 3pt was one of the best 3pt discs ever built. I have 5 discs two of them are your cheaper TSC discs and two of them are old IH pull type and one of them is an old 7ft King Plow company disc. It is a 4 gang but I can only run half of it behind my TO-20 because I can"t keep the front end on the ground and my front tires are loaded but it cuts in one pass what one of the cheaper discs couldn"t do in three passes. Also don"t forget the Ferguson 9 shank tiller. It was designed to be used instead of moldboard plowing. They are a very handy plow to have.
volksman79
10-14-2013 17:54:30
 Re: Bottom plow and disc harrow in reply to Jason S., 10-14-2013 16:55:51
I was just looking at the 9 shank and it looks more like something we need. My tires are loaded and I also think I am going to make a front weight block. We are reclaiming old farm land that has turned into a small forest. Clearing the trees and stumps first them working the ground with compost and lyme to get it back. I am almost positive it was the original garden area of our house back in 1832. This use to be The farm on our road. THank you for your help. I am just learning and it always help to here from people that do it.
oldmisterbill
10-17-2013 21:58:37
 Re: Bottom plow and disc harrow in reply to volksman79, 10-14-2013 17:54:30
Where In MA do you live Volkman? I come from Pepperell.
volksman79
10-14-2013 18:08:06
There are a lot of rocks here it is Newengland. Do the 9 shanks have springs or are they fixed tines?
Jason S.
10-14-2013 18:39:01
 Re: Bottom plow and disc harrow in reply to volksman79, 10-14-2013 18:08:06
They made them both ways but most of them you find are the spring loaded shanks. Ferguson was a 9BO Tiller, Ford called theirs a Field Cultivator but it was the same plow. There are companys that make brand new versions of those plows to this day. I think Fred Cain is one of the companies that still make them if you can't find a good used one. If you look a few threads down for my plowing comparision thread you can see the ground I plowed with one compared to a moldboard plow and my disc plow. They are a very handy plow to have you can work up new ground, you can spread the spacing out and cultivate with it, it leaves the soil in good shape and doesn't compact it like a disc does.
volksman79
10-14-2013 18:58:54
 Re: Bottom plow and disc harrow in reply to Jason S., 10-14-2013 18:39:01
Good to know. I did find them in all sizes. I just can not seem to find one near Mass. I will keep looking. I like they way they seem to work and I think it will be a good fit here.
volksman79
10-14-2013 18:31:49
would the 5 shank be a good option if I can not find a 9 shank?
Jason S.
10-14-2013 18:46:41
 Re: Bottom plow and disc harrow in reply to volksman79, 10-14-2013 18:31:49
I don't think the 5 shank would cover your wheel tracks or you would have to spread the shanks so far apart that it wouldn't do a good job plowing. Early Ferguson tillers were 7 shank so they would be ok.
volksman79
10-14-2013 19:00:15
 Re: Bottom plow and disc harrow in reply to Jason S., 10-14-2013 18:46:41
I am going to look for one of those. I think the 9 shank may a be a little big for the areas i need to work beside the garden. The 5 shank does look a little small.
