TractorLinks.com
Show Parts for Model:
Tractor runs bad after in warms up
Anthony Carter
09-28-2013 15:12:18
I have a TO-35 Gas and when the tractor gets hot it acts like it is flooding and runs bad. I have replaced plugs, wires, coil, condenser, and set the points but it still runs bad. Any ideas.
Trac
09-29-2013 05:52:45
 Re: Tractor runs bad after in warms up in reply to Anthony Carter, 09-28-2013 15:12:18
replace the key switch it's cheap and easy to do they wear out
John(UK)
09-29-2013 04:49:34
First impression is that It is an electrical problem, something breaking down when it gets hot. Have you done any other work on it before it started doing this? Are you using the recommended gaps and Carb settings or are you just using general settings? Have you altered the ignition Timing at all, if it is retarded it can do this. It is not going to be straight forward it will need everything to be checked individually. If you need the information to set everything, email me and I can send it to you, but tell me again all about it when you do....John(UK) fergusontractors@hotmail.com
Bob (Aust)
09-29-2013 04:24:31
Many years ago my TEA20 ran rough when hot and was impossible to start. Turned out to be vapour locks in the fuel line that goes around the back of the engine, due to engine heat.
jon corbett
09-28-2013 18:06:02
hmmm,while running spray intake manifold where its mounted to the engine block and to the carb.i suspect warping when heated up.wd-40,etc.u'll hear the differance
VT parts
09-28-2013 17:52:35
Water may be leaking into the cylinders due to a cracked block, warped head or blown head gasket.
RENE'
09-28-2013 15:51:11
Check valve lash mabe to tight.RENE'
