TractorLinks.com
Show Parts for Model:
Re: voltage regulator
s19438
09-23-2013 11:02:33
as per your suggestion I looked at the back. it is pretty much rusted over and using a mag. glass I could find no ID on it.
JMOR
09-23-2013 12:13:56
 Re: voltage regulator in reply to s19438, 09-23-2013 11:02:33
If you have a variable DC power supply, you can connect it between ARM and Ground & raise the voltage until you see or hear the cut out section contacts close or monitor BATT to ground with light or meter (voltage becomes present when cut out contacts close). If closure occurs when variable supply reaches around 7 volts, the it is a 6v unit and about 14v for a 12v unit.
