Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump check valve?
Lester M
09-19-2013 10:48:41
I checked and made the adjustments for the control linkage and I still have the same problem. With no weight on the lift arms, I move the lever to raise position and the lift arms come up. I add 50 lb of weight to the lift arms and move lift lever to raise position and the arms start to raise but then stop. I can see thru the side inspection that the control valve is moving rearward. I can reach my fingers thru the hole and hold the fork and valve I forward and the arms work properly. Somehow, hydraulic pressure is moving the valve rearward. I am beginning to think I have a pump internal leakage problem.
