1948jr
if you remember i bought a to35 without a pump in it. i put a pump in it and the lift comes up but will not go down. what is wrong now? thanks.
how much oil is in there when you see it move only because it may not be hooked up right or came off the valve
did i raise it too high? is that what caused it to stick? if i keep it running will it break the top?
breaking the top is pretty rare thing. I meant drain the oil so you can see the control valve move the lever atached to the H control arm then valve is on a spring it's a round spring over valve just so you can verify it's working correctly
Your control forks need to be in this position on the roller of the pump control valve.....
Sam
when i start tractor the arms come up and stay . i took that 2 bolt cover off and oil is up there when i push arms down oil shoots up.
