TractorLinks.com
Show Parts for Model:
Re: TO30 hyd pump
Jason S.
09-17-2013 20:40:46
There have been a few exploded pics posted on here of the TO-30 control valve with the oscillator. Usually if the lift works ok but the lift arms get stuck up or get stuck down then the control valve is sticking. Could be caused by dirty hydraulic oil or the control valve itself. The outside of the control valve originally had an almost mirror finish to it. If it gets the slightest pitting on the outside of it from moisture in the hydraulic oil over the years, the control valve will stick and needs to be replaced. You can not buy the TO-30 control valve anymore but you can get the TO-20 control valve and install it and it will work fine.
4440 dan
09-19-2013 17:46:42
 Re: TO30 hyd pump in reply to Jason S., 09-17-2013 20:40:46
would the TO20 control valve have the ocsillator drive?
Jason S.
09-19-2013 19:10:50
 Re: TO30 hyd pump in reply to 4440 dan, 09-19-2013 17:46:42
No it does not, but it"s not needed. That was something they tried that supposedly kept the control valve from sticking but as long as you have clean hydraulic fluid in your tractor you won"t have any problems with the TO-20 style control valve sticking. All the TE-20"s, TO-20"s, and all the Ford N series tractors used the TO-20 style control valve.
