Paul Hearsey
I have, I believe, a 1950 TEA-20 which MAY (says the previous owner) be a junkyard special. That is, assembled from several scrapped tractors. There is no ID plate. I'm confused by the engine. It has a Lucas starter and distributor (#40146D 1050 DBA4), water pump on the block, a 24T-2 Zenith carburetor, a rocker cover with un-recessed nuts and a banjo-bolt type breather pipe and a Tecalemit external oil filter body on the lower left side (under the distributor). I always thought the oil filter was either in the sump or on the right side of the engine.
I looked at the flat between the oil filler and coil for a serial number. Nothing. I scrubbed it down to clean shiny metal. Nothing. No identifying marks anywhere on the engine. How could that be? I'd like to figure out what engine I have without dismantling it to find out. Any ideas out there? I sure could use some assistance! Paul
