TractorLinks.com
Show Parts for Model:
Re: amp meter
Charles in Aus.
09-16-2013 00:51:53
I think you may have it backwards Z man . Bob is correct , when the tractor fitted with a generator [ not an alternator] is at fast idle you can disconnect the battery and the tractor will continue to run . This shows that sufficient voltage is being produced by the generator to power the ignition system . If you do the same with an alternator fitted there is no back feed to tell the alternator how much or how little to charge , this causes it to go into overdrive as far as current production , you risk burning it out very very quickly if you do .
