TractorLinks.com
Show Parts for Model:
Re: amp meter
Z-man
09-15-2013 20:07:31
I'm sorry but I don't believe that is the case with a generator on a 6 volt pos ground system, from what I gather the generator needs the batt to know how much to charge. the alternator works different many it alternates current so yes with a alternator u can do that but not with a generator at least that is my understanding of the system?
Charles in Aus.
09-16-2013 00:51:53
 Re: amp meter in reply to Z-man, 09-15-2013 20:07:31
I think you may have it backwards Z man . Bob is correct , when the tractor fitted with a generator [ not an alternator] is at fast idle you can disconnect the battery and the tractor will continue to run . This shows that sufficient voltage is being produced by the generator to power the ignition system . If you do the same with an alternator fitted there is no back feed to tell the alternator how much or how little to charge , this causes it to go into overdrive as far as current production , you risk burning it out very very quickly if you do .
