TractorLinks.com
Show Parts for Model:
Re: coil getin hot
Jerry/MT
09-13-2013 20:13:12
If you"re using a 12V battery with a 6V coil no wonder it"s getting hot! You"ve doubled the current through the primary circuit. Either put a resistor in the primary circuit, get a 12 V coil (~ 3.2ohms resistance). Check your points; they probably are burned.
Z-man
09-13-2013 22:13:53
 Re: coil getin hot in reply to Jerry/MT, 09-13-2013 20:13:12
I sit possible to use a 12 volt batt and coil while keeping the 6 volt regulator (black square box with four terminals) without changing the 6 volt generator
Z-man
09-13-2013 21:49:31
what about the 6v volt regulator behind the engine that mounts below the batt do I need to change that or is it the regulator for the 12 volt batt
Jerry/MT
09-14-2013 11:05:28
 Re: coil getin hot in reply to Z-man, 09-13-2013 21:49:31
All you electrical system parts must be designed for the same system voltage.
