Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: coil getin hot
09-13-2013 17:19:26
i'm using soild 14 ga wire to run everything is that heavy enough wire or is that part of why it is getting hot? or something else
Jason S.
09-13-2013 19:01:02
 Re: coil getin hot in reply to Z-man, 09-13-2013 17:19:26
If your running 12 volts to a 6 volt coil it will get hot and burn up shortly. Either install a ballast resistor inline to the coil or get a true 12 volt coil.
09-13-2013 19:25:37
 Re: coil getin hot in reply to Jason S., 09-13-2013 19:01:02
ok so far your advise has been very helpful Jason thank you. so if I get a true 12 volt coil will my points work the same? also near as I can tell I'm running on a 6 volt positive ground system so what your saying is I can use a 12 volt batt and upgrade the coil and the rest will be fine and the generator will work on that as well? I need help in this area of the tractor
09-13-2013 20:15:44
 Re: coil getin hot in reply to Z-man, 09-13-2013 19:25:37
6v generator will never charge a 12v battery. A 6v ignition will burn up with 12v gong in w/o the correct resistors. We/you need more info. The 12v alternator and coil need resistance to get it correct for a 6v coil. With the correct coil you don't need the resistor. You'll need to rewire to accommodate the change. Maybe someone will get you a diagram or look it up. Which way do you want to go?
